Hi all, 99 boxster base. Since replacing the coolant my low coolant light blinks....added coolant ...its fine for a while then blinks again then goes off after car is at operating temp. I guess the fluid expands when hot and the light goes out. Toped off coolant opened the bleed valve and drove for a while then shut it to purge any air in the system but light keeps coming back.....thoughts?
