  On 9/7/2019 at 1:16 PM, Vtx531 said:
A little late for me to be asking now but I will ask anyways - Do you put locktite on the water pump bolts? I noticed the bolts had a blue residue on them. I did not use locktite.
Expand
No, we use anti seize compound on these fasteners before torquing them.  Because they are rather small, and adjacent to coolant, there is strong possibility of corrosion over time, which will result in snapped bolts on the next pump swap.  A little precaution now can prevent hours of grief at a later date.........
Just an update. Everything is still good. Here are pics of the pumps so future readers can see for themselves not to get a cheap waterpump. (The white on the impeller is white-out that I painted on to see where it was rubbing)
Edited by Vtx531
