I’ve found that increasingly when I turn off the ignition the car keeps running. I have to put it back in and wiggle it then turn off. Any idea what’s broken? Can I fix or do I need the dealer?
Sent from my iPhone using Tapatalk
The sticky ignition switch replacement is definitely a DIY item. Quite easy, actually. Search here, on Pelican, Rennlist, and/or Utube for the procedure. Sunset and Suncoast usually have the best prices.
Good luck.
Johan
Thanks. Saw the threads about keys getting stuck in. Didn't realize that was the same as keys that don't turn off the ignition. I guess it's all part of the same mechanism.
