Good morning, a few weeks ago, my dashboard limits switch came on related to oil pressure.  The gauge was pegged at a 5 and didn't move.  I shut off the engine, then restarted it.
The pressure gauge reset itself and worked well again.  This has been an intermittent issue.  I bought a new pressure sensor but haven't installed it yet.   Yesterday, I started the engine
and got an oil pressure message and the gauge showed zero.  I turned off the engine, then restarted it and everything went back to normal.  Sorry for the lengthy post, but my question
is... Is this the pressure sensor causing this or could this be leading to something more serious?  Oil pump?  I'm leaning towards a bad sensor getting worse.
Thank you.
