I am getting a squeaky noise from under the hood. Was not able to identify the exact location of the noise. I have changed my serpentine belt, assuming loose/worn out belt would have caused it, but the noise didn't go away.
Sometimes, I have seen intermittent "Oil Pressure too Low" warnings on the instrument cluster, but the warning goes away when I turn off the engine and again turn back on. My oil levels have been pretty stable. I have recently changed my engine oil too, but the noise is still persistent.
I am also thinking to replace idle pulley, not sure if this would fix the issue.
Can any one help me diagnose this.
I had a dealer diagnose this issue. My air oil separator diaphragm had gone bad(which is located inside engine). No more squeaky noise after replacing it.
