I have a 1999 996, and wanted to know if the PCM part number 996.642.105.02 EFR is the correct one to install for the model year. I have read that the PCM2 will not work with the 1999. Does anyone know? Thank you
Izzy
Dear Izzy,
PCM 2 will not work in your 1999 car unless you spend an awful lot of money to install the differing technology that PCM 2 uses to operate over that of PCM 1.
The PCM 2 unit uses technology which allows Audio and communications data to be exchanged between the radio, CD autochanger, Telephone and BOSE Sound System using a new digital bus technology called Media Orientated System Transport, or MOST for short. It uses fibre optics to transfer audio, navigation and CD autochanger data between these system components.
Hope this helps?
Ron
Thanks Ron, that clears the PCM question.  Is the part number above PCM2?
The part number above is for a PCM1 early version. It was replaced by 996 642 905 04 EFR -- still PCM1.
