Dear all,
I am new here, just got my first porsche and did something stupid 🤐 . I changed the oil but forgot to disable the levelling. Now after a short drive the car says it is at it's "normal level" but the rear right side is at his highest possible level. The Chassis warning is on also......
Now i read a lot on internet that its possible to re-calibrate the system with the durametric, is this correct? someone has experience with this system?
Thanks in advance.
On 8/3/2019 at 7:39 PM, Clean-d Ramenwasser said:
Dear all,
Thanks in advance.
IIRC the durametric cant do it, maybe a revision is out by now  I don't know. I used vagcom to do mine as the module is basically from the vw Touareq. It will depend on the year, up to 2006 will work. After that I'm not sure it works with vagcom.
