I am interested in buying a 2000 Porsche Boxster with a 1999 Porsche 911 3.4l /at least that is what I’m told / but it is throwing the cam deviation code, i am not knowledgeable with these cars, he also said he thinks it needs timing pads. Any information would be appreciated
Hi Cody, how many miles on the Boxster and how cheap? My suspicion is that it has a failing IMS bearing. If you’re not familiar with the term, google it and you’ll get quite the education on Porsche engine problems and potential cost in the thousands! If it’s cheap enough and the condition warrants, it may be worthwhile to peruse. Let’s see what other forum members have to say. Good luck.
I would run from this car unless you are into spending lots of money.  Excessive cam deviations on a 3.4L are due to wear on the chain rails, which requires engine removal and disassembly.  An expensive proposition because there will also be many other wear items to replace while engine out.  Unless this is absolutely the car of your dreams, I would keep looking.  Cheap Boxsters are all over the place.
