Hello, I am very interested in draining the fluid in the Tiptronic S.  My Arizona daily driver 2007 997.1 C4S has 80000 miles and I would like to know exactly what type of fluid to get and how many liters. Will also get the filter and gasket.
I understand the capacity is about 9 liters and about half of that can be drained, and was thinking that after the initial service (filter, half the fluid) I will drive it for a few weeks so that it mixes,  then drain it again (this time without removing the pan and without replacing the filter) and thus will have replaced 75% of the fluid. Is that reasonable or is it crazy?
Also does the front differential fluid need to be replaced? If yes, what type and how many liters? Is there a rear differential?
Thank you all.
Thank you all.
You will get 5-6 liters of old fluid out of your Tip, and changing it a second time is not a bad idea.
This should help you with the front diff:
I got the supplies from my dealer, and would like to get the screw connection hose No. 9507/1 A (or equivalent) to be be able to connect to the  charging valve. Any ideas where i should look?
I am considering the MityVac adaptor for Benz 722.9 Auto Transmission that has a 12mm thread. Wold rather not buy the whole set with multiple adaptors for various brands, if I can get the right one upfront.  Can anyone ( @JFP in PA @Loren) tell me  what thread does the filler valve need? I would gladly buy the Porsche tool but if not available, any replacement would do.
Edited by Koenbro
typos
We made our own using  a 134A line with a M14X1.5 adaptor on it to connect to the fitting on the pan. You can also buy Porsche's line, part# 000.721.950.71 Connecting hose -- US MSRP $40.05.
Thank you @JFP in PA I ordered the Porsche hose adapter from my dealer. When I lifted the car, however, noticed that the underbody panel had some fresh oil leak on it -- was not there a few weeks ago when I looked under the car.
After removing the panel, it is from the front of the transmission, and it is not red like the Tiptronic fluid. Could it be the all-wheel driving mechanism?
PS. Just to clarify, although one pic shows a jack, the car is supported by four jackstands in the factory-recommended positions, plus a fifth stand under the rear suspension on one side. Thought I'd mention that.
Edited by Koenbro
  • 2 months later...
