Does anyone know the torque setting for the 12mm bolt on the back of the cam on the passenger side of the engine.  The bolt holds the sprocket on that drives the belt that drives the power steering pump.
Also, does anyone know where to buy the bearing that goes in the alternator fan.  I can buy the holder with bearing for $140 but all I need is the bearing.
Burnell Curtis
