Hi just purchased 2005 9pa in UK,  140,000 miles 3.2 V6
All seemed ok till the rain today 😞
Front windscreen is steaming up badly now,
Parking sensors are now  been totally erratic  for some reason
Sidelight/Indicator  error now
just wondering if this is a bad earthing problem with wiring
your help is is appreciated thanks
Gordon
Cayennes are notorious for grounding (earthing) issues.  They also are notorious for the sunroof drains becoming blocked and causing leaks under the carpet where there are wiring harnesses.  Good luck!
Have your battery load tested also. A weak battery can cause all kinds of strange electrical faults.
If the battery is 5 years old or older I suggest you replace it.
