2012 Porsche Cayenne V6 Base had the Check Engine Light come on last night. Oil Pressure is showing 2 1/2 - 3 Bars on the Dash Gage, drove home plugged Schwaben Porsche Scan tool to is showing a P164D00 Oil Pressure Switch malfunction and P218700 and P218900 Bank 1 and Bank 2 Fuel Metering System, System Too Lean Lean.  Is it possible that the fix for this could be as simple as a Oil Pressure Sender replacement? Suggestions for other possible causes? Appreciate the help.
