I have a 2005 997 Cabriolet, was moving very slowly and top was almost all the way down, but since then the top works funny going up or down, any ideas. Is this a calibration issue?
Good afternoon Dean,
I think this could be an issue with your actuators or your pump. I would check your hyd fluid level in your pump. After that, I would check your the inner wheel well of your rears to see if hyd fluid is leaking. If this is the case, then its an actuator that is failed.
Jim
