Hello
My driver side door in my 2000 Boxster, locks up, I hear the central locking system engaged but cannot open the door from the inside or ourside.
The only way it opens is by pushing the the door from the outside a couple of times and them it opens.
Not sure if the door lock mechanism is bad or if its something simpler.
Any help here would be appreciated.
I had the same problem and it was the door lock mechanism. When neither of the inside or outside mechanical devices can open the door, and unless the switches at both locations happen to fail at the same time, in my opinion, there is no other option. I replaced the door lock mechanism and now works fine.
There are several postings as to how to replace. It is fairly a simple process, although a little bit tricky getting it in and out  of its position. I did it, so I'm sure most people would be able to do it 😎
