This is a 2002 Porsche boxster with 145k miles on it. Regularly serviced, and spark plugs, oil, coolant resivour, air oil seperater, tires, and maf sensor have been replaced within the last year. There is a wierd ticking sound comming from the wheel well driverside(u.s). This ticking only occurs when the car is down revving and is usually below 1300 RPMs. I do not know what the issue is. It does not occur when engine is fully warmed up. And it doesn't do it on every Rev. Just every now and then. Please help if you suspect anything. Thank you
