Hello,
Recently fixed a broken plunger on the driver side door lock actuator and I removed the airbag to get at the door lock assembly. Unfortunately, I made the mistake of plugging in the battery in order to test to see if the replacement part would work without replugging in the airbag. This obviously turned the airbag light on. I was wondering if anyone in the Calgary area would be kind enough to reset my airbag light, as the dealerships and the mechanic shops I have called around to won't touch it without a 500$ diagnosis of the light. I am located in Calgary, and any help would be greatly appreciated.
Thanks very much
