This afternoon I got the "Warning battery/generator" light on my cluster. I put a meter on the battery and it's 13.5 V at idle but if I rev the engine the dome lights flare, the engine compartment fan flares, the voltmeter on the cluster varies and the climate control shuts down. Somewhere in the dusty recesses of my memory I seem to recall these are symptoms of a bad voltage regulator? The battery is only a year old and is kept on a tender over the winter. The drive belt is only 2 years old. The car has under 37,000 miles.
Sounds like it.
