Hello all,
Would appreciate advice on correct engine oil pressure at idle when car is up to temperature.  MY 2001 3.4 C4.  Oil P at start up goes to 5+ then gradually reduces when engine up to temp.  Pressure varies accordingly with engine revs
My car shows 0.7 > 1 bar on the gauge at idle (oil levels are good 5/40 wgt) any advice on possible culprits or whether this can be remedied or whether this is normal
I think the reason dporto asked the question is because the oil pressure sending unit is notoriously inaccurate.  Noises and tapping are a symptom of low oil pressure and could be caused by any number of things.  Only a calibrated oil pressure gauge can tell you the precise oil pressure.  That being said, a number of factors come into play.  Age of oil, oil filter being used, and whether the oil pressure relief valve and spring have been replaced with the upgraded versions.  A fresh oil change and filter change is absolutely necessary before diagnosis of something else being wrong.  5 at cold start is normal.  A drop in pressure after warming up is also normal.  Doesn't sound like you are out of spec, but again, a number of factors have to be accounted for.
Edited by DBJoe996
