My shift pattern emblem was taken from my 996C, hopefully by someone who can use it on their own Porsche.
‘Regardless, can someone help with where a replacement can be found. A plain plastic insert will work as well as one with a pattern or symbol.
The thought of replacing the shifter with a solid billet with engraved pattern has crossed my mind, so I would also appreciate any input concerning that.
I thank you in advance for any help.
Steve
Steve,
I installed a short shift kit in my 2003 996 and at the same time changed out the shift knob for a Rennline aluminum billet knob.  I can't remember who's short shift kit I used, but
the shift pattern was a much better pattern.  The factory shift was mostly plastic, the aftermarket shift was billet aluminum.  I did have to sew up a new vinyl boot...
