I have a 1999 RHD Carrea  Convertible
The electric windows work perfectly on switch, opening closing doors, on drivers key and 1 touch.
But
When you lower the roof the passenger window stays up all other windows lowerI
If you now lower the passenger window from the switch so its down
When you raise the roof the passenger window closes with the other windows
Would this be a fault with the roof ECU not putting a signal out ?
Where is the location of the roof ECU ?
Does anyone have a copy of the roof wiring ?
thanks
