2004 Boxster S Anniversary Edition
I apologize in advance if this has been covered here but haven’t been able to find it during my search.
My spoiler seems to be different than other S models (safe to assume because it’s the anniversary edition), it has the same 4 holes at the back but the clips aren’t visible from the front side.
This is is the first step to upgrade my exhaust and I’m already stuck lol
Any help would be greatly appreciated, thanks guys.
Update: Gently pressed a screw driver into the holes (couldn’t figure anything else to do to release it) and it pushed the tabs that are attached to the plastic spoiler that loosened it from the assembly.
Thanks anyway
I used a tiny drill to remove the tabs. I bought new ones from the dealership. When they are installed I found it impossible to extract. Once the plastic is gone and you have not damaged the hole (use a much smaller bit), putting new ones was quite simple. I skuffed up the first one trying to be gentle. It is plastic just work it that...takes seconds.
