2005 Boxster 987 spoiler and roof inoperative
Any thoughts or guidance would be appreciated.
I bought a project 2005 987 Boxster S Tiptronic that had been parked up for 6 months and a reasonable amount of rain water got into the passenger compartment. The rear control module under the drivers seat was corroded and toast, so I replaced it. I also installed a new battery as the previous battery did not hold a good charge.
I now have functional rear lights, but the spoiler is stuck in a slightly raised position and the roof does not operate at all. If the battery is connected and the car is shut off with no key in it, there is a double clunking noise from the trunk area every 30 seconds or so. The parking brake light comes on when I apply the brake. The soft top roof switch does not do anything. The manual spoiler switch does not do anything. When I try to operate the same units from the Durametric 'activations' page, I get nothing.
(Also, the fuel gauge shows totally empty and Durametric reports an issue with Fuel Level Sender, so I have ordered a used one off ebay.)
I scanned for codes using Durametric and got the following 8004 error, which I have googled extensively with no good solution found:
Rear Body Module
Current Fault Codes
8004: Terminal 30 voltage supply motors
Right Door Module
Current Fault Codes
C121: Communication rear control unit (comfort)
8701: Door lock module
8705: Door lock signal implausible
Instrument cluster - 9x7
Current Fault Codes
9112: Fuel level sender
Porsche Stability Management - PSM
Current Fault Codes
4444: Steering-angle sensor not initialized
Updates after some investigation: Fuse A3 was blown, now the rear spoiler extends and retracts correctly and Terminal 30 voltage supply motors error code is gone.
However, still some issues:
When pressing the roof close button, I get a click from the relay, but nothing else. The roof open button does nothing, no relay clicks. I switched around all the similar relays in the holder but the fault did not move.
Whilst I was under the dashboard switching relays around, the convertible deck cover did open then close again, but I could not replicate that again, I do not know which relay I pulled that caused that to happen. (A relay diagram would be very useful.)
I am still getting the 2 clunk clunk noises in the trunk area about every 30 secs.
Thanks Loren. Further updates for the benefit of others with this issue:
I discovered that the convertible roof relays above the drivers footwell fuse box were clicking, but not actually working. The relays did not switch any current when I applied voltage to them. I replaced both and now have an operational roof motor and lifting decklid cover. I guess it has not moved in many years as the first thing that happened when the roof started moving was the 2 plastic ball joints broke immediately. I have ordered $30 OEM replacements from ebay.
I also found 2 loose triangular plastic trim covers trapped in the roof mechanism, one on each side.
The double clunking noise has stopped, so I can now leave the battery connected all the time.
So now, after all those fixes, the roof went up and down correctly 2 or 3 times, then I get an error on the dashboard about 'Convertible Top Module Error' and the switch no longer works, neither does the Activation command from Durametric.
Where would I locate the Convertible Top Module?
Also Fuse D2 (15A) goes to ground. It says it is the blower motor for engine compartment (997) in the fuse diagram. Any suggestions on whether this fuse should be 12V, and what it actually powers on a 2005 Boxster S 987.1?
Edited by SpawnyWhippet
  • 4 weeks later...
  • 3 months later...
i'm having same issues with my 2006. Top will not work, no sounds, no errors on dash display. I called the previous owners service center (independent) and they mentioned it came in for top problem and they got it working with fuse replacement. I don't have the owners manual so i don't know where to look. Few days ago the rear spoiler stopped working and i cant get the trunk open! wtf.  Related?
