I am about to pull the trigger on my first 911, located 9 hours away.  Will fly in to buy and drive home.  What tools should I take with me on my carry on, just in case?  What should I buy before I hit the road?  Thanks
Make sure the wheel lug lock socket is with the car.  Check the spare tire pressure.  Check all fluid levels.  Enjoy the drive home.
Last month I flew to California and drove back my new to me 996 c4 cab cross country back to Delaware. Flew out with a standard tool kit. Sockets, open end wrenches, torx set, screwdrivers etc.
bought antifreeze and a jug of oil.
Had slight antifreeze leak that went away when the engine was warm and just leaked overnight. ( main line into slip fit mount)
car ran flawlessly, up to 147 at times. Mostly maintained a steady 90.
Fun ride with my son.
Good luck
Good luck
Keep a close eye on the Expansion Tank. I well known part to fail and leak. Not easy to install, but Jake Raby posted a video showing the process on his Rennvision Channel.
Looks like I missed out, offered $24k knowing it needed front tires, brakes and rotors.  Seller said 25k or highway
Drove my '02 cabriolet with almost 50K miles from Minneapolis to Portland in the blazing August heat based on a PPI and optimism.
Only trouble on the way was key fob failure.
Will not be posting max speeds through ND and MT.
If you're buying a fussy fragile cabriolet, familiarize yourself on the emergency up and down procedures and make sure the you have a Phillips to undo the back panel.
Then think positive thoughts, smile and enjoy the ride...
