2011 Cayenne base. Got sloshing water sills when driving. I've cleared out the drains behind the front wheel inserts, but no water came out. Can someone show me where the other plugs (likely lower in the sill area) so I can drain all this water? My Cayenne doesn't have the spots I see everywhere on the earlier models. Thanks!
I've cleared the drains in the front wheel wells. But there is lots of water sloshing in the rocker board area. I can't see the rocker drains everyone shows. I'm starting to think it's behind a trim piece. I'm going to try and remove sone stuff and find it today. Thus us an atrocious design. Surprised there isn't a class action/recall for this huge design failure.
Sent from my Pixel 3 XL using Tapatalk
  • 3 years later...
Did you find the drains in the sills? I can’t find them. All the YouTube videos show them on older models but not on my car (MY2016 hybrid)
  • 7 months later...
I had issues in the passenger footwell area.  IIRC, I had a clogged AC condensate drain.  Lots of vids on YouTube for passenger footwell leak/wet passenger floorboard.  May be the water you’re hearing.
