I have a 2005 997.1 S. When I open the drivers side door both windows completely open. If I open the passenger side door (from outside or inside vehicle), all is fine. Once i enter the car and drive it after I stop and open drivers side door windows drop again (although they only drop once the key is removed from ignition). I've tried the reset procedure many times with no success, my mechanic has had no success trying this as well. He believes replacing the drivers side door actuator my be the issue, but no guarantees. He's never encountered this before. Any thoughts would be appreciated. thanks.
as a follow-up, replaced the drivers side door lock actuator and all is good now.
