I have a 2001 996 and after having the oil changed, I started hearing a squealing sound. In the past I change the drive belt and I noticed that there was no longer adequate space between the engine carrier and the engine block to change the drive belt. Can anyone tell me whether if there should be spacer's between the engine block and the carrier?
There should not be any spacers between the engine block and the carrier. You have twist the belt 90 degree to make clearance at a few spots.
