Ok so I have looked at all the forums and can't find one that is relevant to my problem.
I had a rear right window regulator break. The window was stuck 4 inches open. Then I started getting alarm problems where it wouldn't lock the car and activate. Then it progressed to the alarm horn going off when I started the car with no indicators flashing then the trunk lid and window won't open. The batt is good. The key batts are good. I'm wondering if the alarm module needs replacing or the rear right door is it.
Any help is much appreciated.
