Hi, does anyone know the correct routing for the hood release cable (NOT emergency cable) on an early 996 or Boxster?
On my car I'm refitting the arch liner, and there are two rubber grommets on the hood release cable. These are positioned near the fuel filler pipe like in these images below:
I'm pretty sure they were attached to... something? I can't figure out what they originally fixed to, or is this cable just left flapping about above the arch liner?
  • 2 months later...
Check out if the rhd part number for the release cable has been used on other porsche models too. I bet it has and only in the other use cases the grommets are used.
