So I'm getting the seats redone. Should I put my ctek on battery? will this be ok? Or should I disconnect the battery before removing seats? I heard that I should not put key in ignition when seats are out or dreaded airbag light will come on and will have to get it reset. So wondering if the ctek is ok to keep battery charged.
So I'm also going to take out the immobilzer and add the ecu doctor waterproof box. Any tips? I saw install video and looks easy.
Sent from my ONEPLUS A6013 using Tapatalk
For a first timer. I would recommend disconnecting the battery.
