Hi ,
I have a problem with my cayman .
The aircon does not work .
the gas is ok , and there no faults in the ecu of the clima. Also , when i put the a/c on i see the ecu receves the comand for the a/c.
When i check the pump in the ecu it stats : ok.
But what i notice is that the fan’s also not start in front like normal when you put on the a/c.
Can anyone tell me where the relay is for the a/c ?
