Hello everyone! First post! I was told the were instructions on PSE retrofit here but cannot seem to locate them. Specifically in looking where to tap into the vacuum line for the valves. It seems to be different for S models and base models. I have a Targa 4.
Thanks in advance for any help offered!
Mike
Mike
Figured it out on my own, fairly straightforward.
Sent from my Pixel 2 XL using Tapatalk
Hi Mike.
Did you find instructions for the whole job? I'm considering it but wanted to see first how much work was involved.
If you did and can share that would be brilliant please.
Toby
Sent from my LYA-L09 using Tapatalk
Hi Toby,
I used this as a general guide, it should be very similar to any valved exhaust you plan on installing. Hope it helps! I hope they don't mind installation links here - Akrapovic Install
Edited by Mike Robins
  • Like 1
