So I currently have these fault codes on my 957:
470: CAN gate way single wire operation (open circuit)
1299: Gateway no signal
1336: CAN comfort off
I'm lead to believe I have a disconnection/corrosion in the wiring along the CAN comfort wire (high or low). Can someone I understand a lot of the CAN wires run underneath the passenger carpet, but can someone pin point which wires to look for exactly? Also, I was not able to find the workshop message for fault code 470. If anyone have an access, it would be great if you can share.
