I would try it without removing the ball joint first. Remove the swaybar first to relieve the pressure. If you can get the wheel hub down enough to get the old strut out (and the new strut in) then you won't need it.
If you end up needing it then just buy or rent a ball joint tool (that fits Porsche).
Thanks Loren, BTW I nfind two pn's for the C4S,
4450038 I believe is the x73
445003X is just the euro 20mm lowering kit I think.
Loren, do you find a different pn for the row 20mm lowering kit vs the x73 for thje C4S. Gert lists two different parts on his site, I'm trying to get the x73 not the lower version of stock, HELP, I'm so confused.
You lost me there... there is only one x73 kit for a C4S on Carnewal.com.
There is a kit for C4 "turbo look" - which will I believe is the RoW standard sport suspension for a C4S (this is lower than the US standard sport suspension). If you are not sure email Gert - he is very good at getting you the right parts.
Some porsche dealers are selling the lowering kit as the x73, claiming they are one in the same at a dramatic price reduction, that's where the confusion set in. I can't believe they are one in the same, different pn's, right?
