I am getting what i am pretty convinced is a failing front wheel bearing "whine" from my 2008 Cayenne S.
Does anyone know the ballpark replacement charges for replacing both front wheel bearings?  I have a great independent Porsche shop nearby and I will probably get them to do the work.
Looks like *** bearings on Pelican Parts are about $92 each.
Terry Watson
Porsche "Book Time" to replace both front wheel bearings is 4.7 hours times your shops hourly rate.
Porsche "Book Times" are usually a high estimate - an experienced tech can usually do the job in much less. So let the shop quote time - as long as it is under the "Book Time" you are likely good.
  • Like 1
