When I unhook my battery it resets switch to allow the window to go up and down when door is opened and closed but only works a couple of time before it stops going up and down.
:welcomeani:
You need to re-train the windows. You do so by pressing and holding the button down - all the way down and an additional 10 seconds. Then do the same for raising the window.
It's been covered here many times before so give our search a try next time.
