Loren,
I read a thread on rennlist about how to put a connecting wire from the radio to the fuse box in order to get the speed sensitive volume control to work with DSP. I also read somewhere else that things a different for a Boxster vs. a 996. Could you please help. I want to make sure that I'm doing this properly. Can you provide step by step instructions for a 996? Also, could you please provide a list of items I'll need to buy for the project? Wires, pins, etc. Thanks so much.
The Boxster method is here.
In theory you can do what I suggested to racer08 on Rennlist. That would be to run the SDV control to radio to override the DSP control. If all else fails you can always remove the DSP -- most folks think it adds very little anyway.
