I'm sure the answer is probably somewhere here, but my search-fu is letting me down.
I want to change the transmission oil in my 2005 C2S next week.  I've got 3 liters of Mobilube PTX from Suncoast, but concerned if I have enough.  I don't want to drain only to find I can't fill up completely.  Should I order another liter to be on the safe side? (I'd rather not if I don't have to)
For those that have changed - how much did you end up using?
Technical data
Transmission type: G97/01
Equipment: 6-gear
Installed in: Carrera (997) and Carrera S (997)
Model Year: 2005
Transmission ratios
1st gear: 3.91
2nd gear: 2.32
3rd gear: 1.61
4th gear: 1.28
5th gear: 1.08
6th gear: 0.88
Reverse gear: 3.59
Final drive ratio: 3.44
Filling capacities
Manual transmission
Filling capacity for dry transmission with differential  Filling capacity 2.9 litre
Manual transmission
Change quantity for changing transmission oil  Filling capacity 2.6 litre
