Trying to locate drain locations of each..my rear convenience module will not communicate (suspecting water leak in its area from roof?)and I have wet passenger footwell wires under passenger carpet..no breaks in wiring under carpet.but rusty area on the firewall next to fusebox..any help out there please?
Check out this thread.
WWW.6SPEEDONLINE.COM
Cayenne Turbo - Sunroof drain - I Know this is discussed 1000 Times . Problem with clogged drains. Acces from The sunroof is easy. But i would like to Know where are this tubes ending. Where is the Exit. Somewhere in the Engine compartment? Or this Place behind the Wheel well liner? Thank you for assistance.
Sent from my iPhone using Tapatalk
  • Thanks 1
Cayenne Turbo - Sunroof drain - I Know this is discussed 1000 Times . Problem with clogged drains. Acces from The sunroof is easy. But i would like to Know where are this tubes ending. Where is the Exit. Somewhere in...
Thanks !
