I have a small leak of some fluid coming from a line and clamp area under my 996. I am not sure what the fluid is and if this is a clamp with an o ring inside. Can someone please help me by explaining the function of this. I have attached a picture that I have circled in red the area.
thanks
thanks for the quick reply. Yes the ac is cold. It was just a minor bead of fluid by the clamp. Do I have to drain the system to replace the o ring. I am not sure if this is part of the charged system.
Yes, all those lines are under pressure with a//c on or off. The only way to fix it properly is to evacuate all the refridgerant, replace the bad parts, then vacuum and refill.
