Hi everyone, thanks for letting me join you forum.
This is a old question, but Please help, on a 3 chain engine Do i need to remove the chain tensioner under the air con unit to change my IMS bearing
2.7, boxster, 2003
2.7, boxster, 2003
Expand
Welcome to RennTech :welcomeani:
No, as long as you follow the rest of LN Engineerings instructions to the letter.
Expand
Hi, thanks for the reply, i am going to fit the LN Engineering ultimate IMS retrofit kit.  I have the two sets of tools to do the work from them and i  intend to order the kit tomorrow
HI I think you are talking about a different bearing, this is not a bearing, its a solid outer and inner shaft
it works like a crankshaft bearing
Since the LN bearings are made uniquely for them with unique races and other parts of the kit also unique ... and since the instructions have gone through many revisions to improve them and since the LN tools are designed to make the process successful ....
Not ever saying that other approaches can't be successful.
Thanks for the reply, can you please explain your last email, my question at the start of the topic was, do i or do not remove the front engine chain presser bolt
Expand
LN wrote up the 3 and 5 chain instructions, available online, which should be followed.  My personal preference on three chains is to pull all the tensioners.
  • Like 1
What happened to you first email, you said no, i did not wont to to removing the air con unit, help
But thanks for the reply
At the moment im having a problem removing the water pips around the auto box ie where to start
Expand
Again, I said: "No, as long as you follow the rest of LN Engineering's instructions to the letter. "; and stated that "my personal preference was to remove them all".
Your choice is yours.
  • Like 1
removed the starter and removed the torque converter bolts
rear bumper is off and the exhaust
The wine bottle corks do work to stop the all of the coolant running out
engine is held up with a engine frame
So gearbox out tomorrow and time the engine to fit the LN Engineering timing tools
My £300 roller bearing is in the fridge
Right, made the extra cam locking tool for bank 1, fitted the new locking tool to the other camshafts so all 4 cams locked in place
The LN pine for the front pulley was to long to clear the space from the engine to front panel, so i cut 20mm of the end
Then locked the crankshaft
removed both rear chain tensioners and removed the IMS bearing cover
Used the LN puller to remove the bearing, it cam out with no problem, lots of old oil cam running out of the shaft
removed the new roller bearing from the fridge, it had been there for two days, fitted to the LN  tool and used a copper hammer to knocked it into
the shaft, it went in with no problem and bottomed out with a solid clunk, fitted the spring clip and cover, two chain tensioners
removed all the engine locking tools, turned it over two turns and refitted the the locking tools, both cam locking arms fitted into the 4 camshaft end ok
The rear crankshaft oil seal was leaking so changed it with a Porsche one
Fitted a new brake pipe over the gearbox as it was out
So all day to day fitting the auto box, starter , exhaust, engine oil and filter
Tomorrow is start up day
As you probably found, actually replacing the IMSB is easier than all of the rest of the work to get to that point. I think you are home free.
Hi rochouse66,
thanks for the support,   yes your right, but it makes you think will the chains jump,will the timing be out, will it start up and you cant try to start it until all the parts are back on.
So i started it yesterday, it sounded OK, i have put the top and bottom parts back to day and go for a run in the french country side with the top down.
Tips
 Putting the bolts back into the ring gear to torque converter, place them on a magnet when you remove them, so they stay on the allan key when you fit them, and do not drop down the back  of the ring gear
If you remove the oil air separator you can remove the bottom starter bolt
Make sure the LN cam locking tool fits into the flywheel side of the engine and use the tool to make one for the front cams, you will have to cut it and weld it at the top as the front cams do not line up, i did have the single cam tool to line up the front engine bottom cam but i did not trust the top cam not being locked
You can use a screwdriver to turn the ring gear over to get at the torque converter bolts, after the starter is removed use a mirror and torch to see the bolts
Edited by johnp
spelling
Don't really understand the negative reaction to my post. Bearings aren't magic: they have an inner and outer diameter. LN uses an industry standard bearing which can be sourced from hundreds of places for a variety of prices. I am replacing the IMS sealed ball bearing with an unsealed cylindrical bearing of the same dimensions and lubricating the affair with an oil feed taken from a spin-on oil filter adapter. I've taken a bearing end cap ($50 used) and drilled and tapped it to take a threaded oil line, then I'll run that line through a small hole (or cut out) in the bell housing to the oil filter.
I've been building RR and Jag engines for decades and solving similar oil starvation and vapor recirculation problems with much more exotic fixes than this. I just think the purveyors of the various kits out there for the Porsche engine are taking the mickey out of owners purely because of a problem that, statistically, happens to 10% of the cars not modified.
Don't forget: a 10% failure rate is a 90% success rate.
In comparison, 100% of the early Honda Civic engines that did not have a timing belt change at 11,000 miles intervals suffered severe engine damage yet the replacement kit cost little more than the original equipment part. As an aside: I have heard from more than one source that simply removing the seal on the IMS bearing will lubricate it sufficiently if one uses an additive (STP, Lucas or similar).
  On 5/17/2019 at 6:18 PM, Phavas said:
Don't really understand the negative reaction to my post. Bearings aren't magic: they have an inner and outer diameter. LN uses an industry standard bearing which can be sourced from hundreds of places for a variety of prices. and solving similar oil starvation and vapor recirculation problems with much more exotic fixes than this.
Expand
This is exactly were everyone that thinks they can do better themselves goes wrong.  The LN ceramic hybrid bearings cannot be "sourced from hundreds of places for a variety of prices".
The LN bearing is the final result of a lot of R&D, trying out various bearing materials until they fail, to identify the best selection of components for the final bearing.  And as that design is produced exclusively for them, you are going to have a very difficult time replicating their results  Good luck...…………..
  • Like 1
Expand
Removing the real seal will lubricate the factory bearing without any junk additives.
  • Like 1
For those of you following this email string and want to be more informed on the failure issues and fixes for the IMS bearing I found the attached video by Pedro very informative:
Oh heck, I've said it privately and I'll now say it publicly, JFP has done more IMS swaps than any of you combined. He has to pay in reputation and/or dollars if any of his work fails. He has a vested interest in doing it right the first time. He has no financial connection to LN. He chooses parts for their reliability and their ability to not cost him time, money and reputation. Because if it fails, it costs him in all three areas.
How do I know all this? Well I've been following this issue for at least 12 years to back before any Flat6/LN product was publicly available. I know how many engines they blew up testing. And since LN was the first vendor to produce a kit and the first to produce instructions and tools for something Porsche said couldn't be done, I got interested and was talking back in the day pretty regularly to Jake, emailing to Jake and Charles. How many bearing materials did they use? How many versions of the races? You buy today you aren't getting their first version of either the bearing, the accessories, the instructions or the tools. You'd be buying well beyond the 10 thousandth one they sold.
It is your car, your money, your choice.
He will probably delete this but if it saves someone from going off in a wrong direction...
