After becoming a contortionist whilst changing the ignition switch and nearly killing the cat with the shear frustration of it all, it happened again :cursing: ie when I turn the ignition key to the left and pull it out, the engine doesn't shut off.However when I switch off the lights ,the engine cuts out!! :cursing: Please don't tell me I've got to get under there again!
What is the connection-mechanical/electrical or otherwise between the ignition key lock /switch area and the light switch? (ie Headlights etc)
TIA
Jason (98 996 C2)
I had this exact problem and it turned out to be nothing more than a rear left side stop/tail light bulb. The internal centre earth connection was faulty.
  • 4 weeks later...
