Hi this is my first post
Trying to get the car roadworthy after standing out for 7 years
Running fine but can only emergency lock from the key with the single beep after 10 seconds.. The fob led flashes when pressed and the dash status led responds but the car will not lock.
When I remove the ignition key the park led in the instrument cluster remains on and does not go out even when emergency locked. There is a battery drain of 0.8 Amps which is still present overnight.Not sure if this may be an ignition switch fault keeping power on to the cluster and this is preventing the remote locking and alarm from working.
Any ideas appreciated?
