Driver side window does not drop on either the inner or outer handle. Also have notice the interior lights do not come on when the door is opened.
Passenger side all works fine.
Also note, the battery went flat recently.
Any ideas of the cause of this?
TIA
First thing to check would be a bad fuse if switch isn't working at all. If switch will raise and lower window you need to completely raise and lower the driver and passenger windows  twice to reprogram window any time battery has been disconnected, or I our in your case, completely discharged .
As for door , check the that position on the switch in the over head console is in the center position. . Battery going dead would not  effect the door lights once battery issue was corrected.
Edited by dphatch
