1997 Boxster original California car with 118,000 miles on the odometer.
Last digits of the VIN#  S625521
the engine Ser# M96/2065V15144
Are the last few numbers suppose to match?
If yes and they are different, any way of finding out more details about this engine?
The engine sounds good at idle with good balanced exhaust flow & no blow-by from the crank case.
Thanks to this community I have decided that it should be pulled before seeing another life of pleasure.
Debris in the bottom of the pan shows eminent IMS failure as well as pieces of plastic from a chain guide or tensioner.
Although an electric motor expert, I feel quite comfortable with this project.
In fact I am very impressed with the engineering gone into these cars! ( Albeit the IMS thing : )
Jacking this car one sees just how well balanced they are, simply amazing.
This particular car has absolutely no rust, for me this will be a pleasure to work on!
Cheers,
Mark
In no way do  the VIN numbers and engine numbers match on a Porsche.  About the only way to find out if the engine is original to the car is to order a Certificate of Authenticity from Porsche with the VIN.  That should list the original engine number.
Thank you for the clarification!
That's some handy resources you have there Loren ...
I considered doing the Porsche Authenticity report, but you quickly learn working on these cars they're not made in China   ; )
Fact is I'm owner number 9.  I suspect many things have been changed on this car and it's more likely seen it's fair share of services centers.
The Tiptronic trany is oily whereas the engine is quite clean  : /
This Boxster is at the point in it's life that it will either be a money pit or a great car for a enthusiast!!
Hopefully the latter ... having done the majority of my own auto repairs from engine rebuilding to body work (ugh), this car has found a good home!!
Mark
