started with P0491 & P0492 CEL that came on after a day driving the car after reset.
Long story short:
Pump works, so moved onto cut off valve since CEL is both banks
Used a tutorial on here where the poster poured seafoam on cold start into the secondary intake pipe to test for leak
seafoam "cloud" came out only on the passenger side exhaust pipe and not the driver side
Im guessing because of this there might be a blockage? Where should i look to next? thanks for your help!
Edited by Cameron Tam
Lots here if you do a Search...
P0491 Secondary Air Injection System, Bank 1 - Insufficient Flow
P0492 Secondary Air Injection System, Bank 2 - Insufficient Flow
Possible cause of fault
- Electrical fault in power supply or line between relay and secondary air injection pump
- Secondary air injection pump relay mechanically faulty
- Mechanical fault in electrical secondary air valve
- Pneumatic secondary air valve faulty/sluggish
- Electrical fault in secondary air injection pump
- Mechanical fault in secondary air injection pump or secondary air injection pump blocked
- Vacuum system leaking
- Air hose to secondary air injection pump slipped off or constricted
Check the connector (perhaps they left it unplugged) then fuse (40A on relay panel near DME).
I solved my codes by pretty much replacing all the SAI vacuum lines.  Take a look at the thread here:
