Im getting conflicting info.. some say there is a code for 2006 Cayenne S PCM some say there is not one.Mine doesn't work so I thought maybe I need  code after my Battery was replaced?I dont have my code but is it even required?
On 2/18/2019 at 9:43 PM, Loren said:
No code should be required unless you physically change out the PCM unit.
I recently changed out my PCM unit because the original stopped working  and suspect I need a code, everything seems to be working ok but I get the following message when I turn it on:-
System error: Amplifier not available
I accept the message and it disappears until I turn the system on again, as I said everything seems to be working ok, anybody came across this before?
