The plastic screen on my 2002 986 has split so instead of replacing just the window I’ve managed to get myself another roof with a glass window which is now fitted and looks great!!! But.... when it opens or closes at the point the roof frame passes the hinge/arm of the clamshell (on the passenger side only) it has to push past it meaning it runs quite hard against the clamshell arm. On the drivers side it passes cleanly with only minimal contact. The clamshell arms have plastic guide plates attached to them and on the passenger side this almost gets pulled off every time because the roof catches it when going past
My question is can this be adjusted??
