  I have done some searches  and nothing seems to match my issue, or the threads simply stop without a satisfactory conclusion.
A friend bought a Boxster at auction which would not go into Park. I checked the cable, links and switch, all are fine. I removed the oil pan to find the link inside has separated from the slide rod. I loosened the valve body enough to reattached the slide rod and re-torqued the valve body. Refilled the transmission with new filter. When cold it selects gears and drives fine. But as it warms up, the selector gets stiffer until it pops out again and I cant select park. Which means as the transmission warms up something is binding the slide rod inside the transmissions.
Does anyone have any insight as to what I should do next?
Rob
