99 boxster...previous owner upgraded the hibeam to xenon available from pelican. Lowbeam is still the H7 halogen.Any reason I shouldn't rewire it for xenon on the lowbeam? Makes more sense considering the lowbeam is used more frequently when driving. thanks v
Can anyone verify the top bulb is the lowbeam...I may have been misinformed as to which is lowbeam.
Ok, I rewired my headlamp harnesses  and all my lights/ fog lights are working as they should. So new headlamp switch is not needed. I did notice the color or intensity is different between my 2 xenon low beams. I read that 1 may not be level with the other. Is this true seems to make sense being if I look into the beams at different angles they both look the same color. thanks v
