Does anyone know how to remove the rear wiper arm ?
With the cover off a nut is removed, but the arm is not coming off. Do I need to remove the actuator under the glass also ?
Nope, all you need to do is remove the 13mm nut. Once thats off just pry the wiper arm off. If you can stick your fingers underneath it as close to where its fastened to the glass, you can kind of rock it back and forth and itll come off.
Thanks PTEC and Loren.
Its an Aluminum self seating mount over a spline. I just used my fingers and rocked it until it released, cleaned the spline of debris and remounted.
